-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   sawsall stump removal (http://www.hotrodders.com/forum/sawsall-stump-removal-138172.html)
skylark65 05-05-2008 11:21 AM
hey just wondering if i could use my sawsall to remove a couple of stumps in my yard, or will it destroy it. i have allready dug around all the roots. my dad ruined a perfectly good chainsaw blade trying to remove other stumps when i suggested the sawsall. any help appreceated thanks.
geezer69 05-05-2008 01:22 PM
sawsall
hi skylark.yep itl work.theres an assortment of blades.try to keep the blade retainer out of the dirt.clean it good when your finished.its a great and versitle tool .i used carpenter tools to chop my top.geezer69
1ownerT 05-05-2008 09:53 PM
It will work great, I used one a few years back to de-root the neighbors tree...on my side of the fence.
TorkMonster400 05-06-2008 02:48 AM
You can cut anything with one thats why I love'em ,I suggest using a bag or a condom with a slit in it over the blade guard I did this trick while working on a jeep in waist deep mud :thumbup:
forestrytodd 05-06-2008 11:02 AM
Why not just go to the local u-rent type place and rent a small stump grinder. Here in the south their cheep by the half day and does a fast clean job. Then you have mulch for the wife's flower beds. And brownie points to boot! :thumbup:
onebadmerc 05-11-2008 09:42 AM
It will be ok if you keep the dirt out of it, if it gets into the housing your sawzall will have a short life.
SuthnCustoms 05-12-2008 12:07 PM
Ive used my Milwaukee Sawzall for the same thing 3 years ago removing tree stumps in my backyard..worked great with a long big toothed typed blade.
As far as dirt in the motor,just blow the housing out when done with an air compressor,mine's still cuttin away after 3 years of serious abuse in dirt..grease..etc.
Mustangsaly 05-14-2008 08:26 PM
I have a milwake and a makita electrial sawsall. I'm a electrician, but beeing disabled I don't do much. but I've cut about anything a sawsall will cut. awsome tool. ooh yeah I like the makita much better. I think its the stroke. I bought my grandms car when she quit driving, it was a 77 Plymouth Fury III and the chrome rear bumper was bent. I got a replacment bumper, but could not get to two of the bolts the way the bumper was bent. so I cut 1/2 the bumper off "quickly" with the sawsall. gota love em ! ! !
Smittydpd 05-20-2008 11:43 AM
Will work fine, just keep out the dirt, very bad juju!
Rob Keller 05-20-2008 03:51 PM
I've cut up many many cars & even more metal with a sawzall {reciprocating saw} .
Use a pruning blade like this{watch you fingers!}
http://www.toolbarn.com/images//milw...48-00-1303.jpg
Mustangsally I will trade you straight up my makita {plus another parts one both with cases}for your Milwaukee! mine always spits out the blade :pain:
Most likely the chainsaw got dirt in the chain & ate up the blade.
I also use my cordless to trim limbs I keep that in my truck.
What size is the stump? :confused:
R :thumbup:
Beenaway2long 05-27-2008 03:00 PM
Chainsaw chains get chewed up because the roots contain sand. You'll find sand up 12" from the groundline. Especially Maple.
Grinding is best.
"The right tool for the job"....
68NovaSS 06-03-2008 02:32 PM
Where did that come from??? :rolleyes: Too funny...
schnitz 06-03-2008 04:18 PM
Grinding is best.
Jeff, try cutting a tree next to any gravel road (within 20 feet of the road) in Wisconsin. You'll find sand all the way up the tree. The reason? Snowplows in winter, and just regular gravel dust the remaining 3 months of the year.
In a while, Chet.
