Sb 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2008, 09:16 PM
Sb 350
i got a small block 350 i want to put in my caprice......its got a high pressure oil pump, roller rockers, edelebrock performer intake.....the thing is i have tbi and i was going to put that on top of the performer with the throttle body adapter, but im wondering if the tbi will restrict the motor from running right....i want to be able to get as much out of the motor as i can.... i put a brand new fuel pump in the car and i didnt really want to convert to carb.... what should i do, or what would you guys do????....
also my car originally came with a 305 and someone told me the computer in it wouldnt allow the motor to run at its best, something about i would need a different computer or something.....does anyone know anything about that or have heard about that......Thanks for a response
Old 09-26-2008, 05:42 AM
change the computer or at least the chip to a 350 one
change the injectors to 350 ones(if you haven't already)
by using all the 305 stuff on a 350, it will run lean
Old 09-27-2008, 11:52 PM
well its throttle body injection....i was just going to get a throttle body adapter plate and put the one from the 305 on it....do i have to do something different to the throttle body????.........were could i get a chip for the computer????......Thanks for a response
Old 09-28-2008, 03:57 AM
DoubleVision's Avatar
replace the knock sensor.
Old 09-28-2008, 08:40 AM
the throttle body itself is the same. the 350 uses bigger injectors.
you can get a chip in the junkyard. find something that uses a 350 with the same part number ECM you have
e85 in '76 sb chevy 350 Cobra9117 Engine 3 08-28-2008 04:23 PM
genral 350 sb questions excaliberprime Engine 2 04-30-2007 04:17 PM
Is this a good cam for a sb 350 chevy? TonyMac Engine 3 03-27-2004 08:12 AM
350 ... Need I Say SB or C??? horvath Engine 25 07-17-2003 03:20 PM
350 SB OR BB GONZALEZ Hotrodders' Lounge 4 05-09-2002 03:06 PM
