SB 400 build help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2009, 10:24 AM
SB 400 build help
I have a 400 bored .30 over. Stock crank .20 under on rods .30 under on mian. 5.7 stage 1 scat rods and Speed Pro .100 dome piston. My rods are hitting my cam and i need some advice.
Old 01-30-2009, 10:39 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Depending on the amount of interference, you can either grind a small area off the rod or buy a small base circle cam.
Semper Fi
Old 01-30-2009, 10:41 AM
I was also told a roller cam will clear too. Is that true?
Old 01-30-2009, 10:54 AM
The rod is hitting about a 1/8" from the top of the lobe. is this to much to grind off the rod before ruining the balance?
Please help me build my pontiac 400 Volvo240400 Engine 12 11-18-2013 07:14 AM
400 chevy build up recipe? boyd1on Hotrodding Basics 35 01-07-2009 03:37 PM
a budget 383 stroker build using a stock 400 GM Crank Mustangsaly Engine 7 10-15-2007 01:57 PM
the best 400 ci chevy sb 86sdub Engine 11 09-25-2007 09:34 AM
400 SB v.s 350 SB 70 nova Engine 8 02-22-2003 02:29 PM
