sb chevy ign specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2002, 07:19 PM
New Member
Exclamation sb chevy ign specs
hey all im workin on my pops-in-laws 34 3w and i was wondering what the points should be gapped at and what the timing should be at idle and at about 5000rpm vacum advance none hei its a 68-69 engine. thanks in advance for the help, im a FORD guy and im doing this as a favor.
stangpower71 <img src="graemlins/spank.gif" border="0" alt="[spank]" /> <img src="graemlins/spank.gif" border="0" alt="[spank]" />
Y'ALL come back now Ya heer
Old 12-20-2002, 08:27 PM
Post
Is it an HEI? Does it have a vacuum canister?
Quote-vacum advance none hei-Quote
For points, start out at .019 and then hook up the old dwell meter and go for 28 degrees. 5000 is a bit high to turn any engine without a load. I'd look for 32-34 degrees at around 2800 to 3400 depending on cam, carburetion etc. Unless someone was smart enough to keep a logbook with baseline figures, you're gonna spend some time experimenting. :xmas:
Old 12-21-2002, 09:40 AM
New Member
Post
well thanks for the info it is non hei it has a vacum advance and unfortunatly noone kept a log and i happen to be the first one to give it a tuneup in about ten years, it has not been driven musch in that time then the carb went bad and i replaced it with my edelbrock 625cfm and got it running but not the greatest. ohwell time to work on it some more, any more tips would be great thanks, Stangpwr71 -Ron <img src="graemlins/crash.gif" border="0" alt="[crash]" />
Old 12-21-2002, 12:45 PM
dmorris1200's Avatar
doesn't play well with others
Post
spark plug gap = .035" 350ci=R44 307ci=R45S
point gap = .019"
dwell = 28-32*
base timing (factory) = 4BTDC with Auto trans
These are the specs out of a 1969 Camaro manual.
I would experiment with the base timing as stated, you can probably do better than 4BTDC.
BUILT FORD TOUGH
