SB Ford Starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2003, 07:37 PM
SB Ford Starter
I am rebuilding my 55 Ford F100 with a 302 Ford Small Block and C4 Transmission. I ordered Patriot "Tight Tuck" headers. Upon getting the headers, instructions indicated that I need a "Short Ford Starter". Obviously, the original starter is too long and will not work.
My question is: Does anyone know of a ford factory starter that is shorter than a 6" case? Obviously, I can get a mini starter for around $160, but a stock type starter will work fine, if it is shorter.
Thanks
Old 12-21-2003, 07:56 PM
Jmark's Avatar
ck with your local good parts store, they should be able to help you.
