SB pulley configurations?
I have a fresh rebuilt 62' 327 that I have trying to get all the right brackets and pulleys for. I have several brackets and pulleys that I pulled off an 84' 305 motor. I will also be running a saginaw power steering pump so I need a little help figuring out what I need. I have done some searching on this site and from what I can tell I need a long style water pump, and alternator on the drivers side. I have a short pump and nothing seems to line up so I think that my problem starts at the water pump I have. Zoops has some good info on their site, but their prices are a little steep for brackets and they start their small block configurations at 63' and later. Any info to help me get this motor on the road is much appricated!
OK, so I'll get a long water pump and go from there. I notice that most places advertise that it will fit applications from 1987 to present? A 62' shortlblock doest have a different water pump, right?
You have to be alert to the lack of bolt holes if you have original heads.
I just went through this exercise putting my '72 together with camelback heads. I believe Chevy used the short pump until they came out with the heads with holes in the latter '60s ('68?) and moved the alternator to the right side. I thought I had it all figured out until I came to the power steering pump. To make a long story short, I finally changed to bolt-hole heads and reverted back to the right side alternator and left side PS, with a long water pump. |
I thought I had it all figured out until last night when I noticed that my head didn't have any holes in them, like you said. These are just redone heads so I am not changing them out because of one threaded hole! What are my options? All the braket configurations I can find all need a hole in the head. There are some holes I can use on the bottom left and right side of the block. It makes more sense because of location to run a power steering pump on the drivers side and the alternator either above it or on the passenger side, but I'll put them anywhere I can bolt them at this point.
327 pully config.
chrome brackets and the air condt on the left side. All fit well. I do not have pwr steering but would put it on left side too, lower than air condt compressor. I would recommend a serpintine pully system if you are putting everything in. I do have regular belt pullys in polished aluminum and will sell both of them for 20 bucks total if you need them. E-mail me if so. STU |
I don't think you ever mentioned what type vehicle this was in, which can make a difference.
There are original bracket set-ups if you're trying to stay original with the short pump. For the alternator, there is a lower bracket that bolts to the two front exhaust manifold bolts. I see them occasionally in the fast food parts stores, in chrome but you can grind that cheap stuff off. The upper bracket is a curved adjuster arm that bolts to either the intake or the water pump. If this is a rear-steer vehicle, Chevy had a PS bracket that bolted to the two unused bolt holes in the lower driver's side block. |
this is just a idea that might not fit your needs...........
this is a lot cheaper than aftermarket serpentine belt setups those no accessory hole heads might through a wrench in my idea (of course if your wanting the original look my idea is out also) I would recommend a original Chevy (87 up) serpentine pulley system, if you are putting everything new in. I have a spare serpentine belt setup with all the accessory's for my next SBC project. on the serpentine belt setup I have in my 87 Suburban (I'm replacing the engine in it now) I'm power coating the brackets and fan valve covers and a few other items, power coat chrome, not as shinny as true chrome but looks good imo and can be done locally. like this http://cgi.ebay.com/ebaymotors/SBC-C...spagenameZWDVW http://cgi.ebay.com/ebaymotors/82-92...spagenameZWDVW ON OLDER MOTORS YOU HAVE TO TAP AND PLUG A SMALL HOLE ON THE PASSANGER SIDE OF THE WATER PUMP PORT THE NEWER WATER PUMP DOES NOT USE OR COVER THAT HOLE you can see in the picture what the style of the front of a motor this came off |
It's a 54' Chevy 210 that I have dropped this 327 into, so the original is already out the window. There is plenty of room under the hood so I am not limited to where it can go.
| Dodge sb serpentine pulley ? | 30desoto | Engine | 1 | 03-25-2006 08:08 PM |
| Strange pulley issue... | Classix_Lover | Engine | 10 | 02-12-2006 07:12 PM |
| SB Pulley Diameter | Sky65 | Engine | 1 | 12-04-2005 11:17 AM |
| Squeeling Fan Belt - Out of true Pulley | Billy Boy | Engine | 3 | 02-15-2005 06:51 PM |
| underdrive pulley | markiemyster | Engine | 1 | 02-21-2003 05:36 PM |
