Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sb350 Problems,-Help!
Old 02-04-2002, 04:21 PM
PAULWELDIT PAULWELDIT is offline
Post
I'M NOT REALLY SURE ABOUT THE HESITATION BUT IF YOUR VOLTAGE OUT PUT IS 16.5 IT WILL DAMAGE THE BATTERY IF NOT EVENTUALLY CAUSE IT TO EXPLOAD(NO EXAGGERATION HERE).VOLTAGE OUTPUT SHOULD BE 13.8-14.2 MAX. CORRECT THIS FIRST!! THIS COULD ALSO BE CAUSING THE IGNTION MODULE TO ACT UP--NOT ALLOWING ENOUGH COIL SATURATION(WEAK OUTPUT) I SUGGEST REPLACING THE MODULE WITH QUAILTY DELCO OR PERFORMANCE VERSION BE CAUSE THEY ARE A WEAK
LINK ANYWAY. THEN TRY IT --IF THAT DOSS NOT FIX IT START CHECKING FOR FUEL CONTAMINATION OR DRIED FUEL INSIDE THE CARB. HAVE FUN!!!WRITE BACK ON THE RUSULTS.
