Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sb350 Problems,-Help!
Old 02-05-2002, 04:30 PM
huffed6 huffed6 is offline
if you just installed the hei dist did you run thru the ballast resister? if you did it may be heating up and cutting voltage even tho when turning on initially you get a good voltage reading .on cranking bypass would show full voltage also. as rpms speed up voltage draw will lesson and resister will cool alowing more juice . just a thought
good luck
