sb350 Problems,-Help!:Problem Solved
I'm back in business!!! Replaced the crappy split-fire plugs w/a new set of champions, ran new ground wire to the firewall and frame and wow!
This machine in smokin' again, better than ever! Thanks for all the help!! Charlie |
Great! We see too many ground problems causing wierd things. You can never be too rendundant with grounds. :D
Now next time go get yourself some Autolite plugs and it will run even better :D Glad to here everthing worked out.I still to this day dont know how they can sell those plugs to the public(split fire).You are not the first to have problems.
I always use autolite myself. I tried all those highpriced plugs, but it ran better on the lites, and they last longer
| All times are GMT -6. The time now is 01:35 PM. |
