SB350 Timing and Compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2002, 02:11 PM
New Member
Red face SB350 Timing and Compression
I'm trying to tune a sb350 but it still runs rough at idle. First of all, what should the idle speed and timing be? Currently, I'm at around 600rpm with about 16 of timing (advance disconnected.) Here is the part that sucks: I checked compression and found one cylinder is at 90, 2 are at 110, and 5 are at 150. The motor still runs strong but idles rough. Will this thing ever idle smooth with these compression numbers???
Thanks for all the help guys!!!
Old 08-20-2002, 02:19 PM
Steve karch's Avatar
Post
Most likely not. Try a wet compression test and see what you get. If it stays the same try some combustion chamber cleaner. Those two holes may be carboned up.
Old 08-21-2002, 12:03 PM
bullheimer's Avatar
NEVER use credit cards!
Post
ditto
