Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 195 degree Thermostat
Old 03-24-2013, 09:57 PM
gonzo08383's Avatar
gonzo08383 gonzo08383 is offline
Last journal entry: brakes
depends on your compression ratio, iron/aluminum heads, octane of fuel, and lots of other stuff. my 350 loves 195*, it really rockets up. i also have to keep premium fuel in it and if it sits too long i have to put additive in the fuel or it will try to run backwards when i shut it off. i say try it out and see what happens. its not like its going to blow up and a t-stat is under 20 bucks. i'd turn the timing down a couple degrees just to be safe tho.
The Following User Says Thank You to gonzo08383 For This Useful Post:
fastnloud (03-24-2013)
