Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 195 degree Thermostat
Old 03-26-2013, 12:04 AM
acme's Avatar
acme acme is offline
Originally Posted by fastnloud View Post
In my truck with a with a built 350 SBC, would it be good to run a 195 degree thermostat, and is it likely to cause detonation? I've been reading about how it may run a bit more efficient with a 195 T stat.
Thanks guys.
From experience I tried the 160, but a 180 or 195 ran smoother and it's better for the oil so it can burn off contaminates , condensation in your oil. Oil likes higher temps anyway.....An efficient radiator will keep a steady temperature that helps too.
The Following User Says Thank You to acme For This Useful Post:
fastnloud (03-26-2013)
