Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 195 degree Thermostat
Old 03-29-2013, 08:22 PM
gonzo08383's Avatar
gonzo08383 gonzo08383 is offline
Last journal entry: brakes
my motor is almost the exact same specs as yours except i run a comp cams thumpr. i have to run 93oct or i get pinging bad. try the hotter t-stat and drill a small hole for bypass. a regular mr gasket should work fine for the experimentation. hotter is more power and if your radiator can keep up you should be happy with the results
