SBC 195 degree Thermostat - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2013, 09:32 PM
fastnloud's Avatar
In my truck with a with a built 350 SBC, would it be good to run a 195 degree thermostat, and is it likely to cause detonation? I've been reading about how it may run a bit more efficient with a 195 T stat.
Thanks guys.
Old 03-24-2013, 10:57 PM
gonzo08383's Avatar
Last journal entry: brakes
depends on your compression ratio, iron/aluminum heads, octane of fuel, and lots of other stuff. my 350 loves 195*, it really rockets up. i also have to keep premium fuel in it and if it sits too long i have to put additive in the fuel or it will try to run backwards when i shut it off. i say try it out and see what happens. its not like its going to blow up and a t-stat is under 20 bucks. i'd turn the timing down a couple degrees just to be safe tho.
The Following User Says Thank You to gonzo08383 For This Useful Post:
fastnloud (03-24-2013)
Old 03-24-2013, 11:14 PM
fastnloud's Avatar
Thanks for the help, here are the specs on my motor, maybe that can help with recommendations
350 4 Bolt Main .040 Over
Scat forged I beam rods
Keith Black flat top pistons 4v reliefs
Moly rings
World Sportsman II heads 2.02 valves and 64cc chambers
Edelbrock performer rpm intake
Holley 750 carb
1 7/8 longtube headers
Lunati Bracket Master II Cam 300 duration
Crane Valve springs
Crane roller rockers
Comp Cams double roller timing set
Also I run 93 octane fuel.
Old 03-25-2013, 07:50 AM
Bonneville462's Avatar
I'd try it, it is defiantly a tuning tool.... Heat is power...
My Pontiac 462 likes the 160 and runs better on 89 octane then having a 190 with preimium.... I had to experiment with it though...
Old 03-25-2013, 11:46 AM
fastnloud's Avatar
My compression is around 10:1, I think. I'm thinking I may go ahead and try one of the Stewart hi flow 195's.
I just hope it doesn't cause any detonation.
Old 03-25-2013, 12:26 PM
fastnloud's Avatar
I'm getting a bit confused, I was going to buy a robert shaw t stat, but you supposedly can't use them with a stock style water pump.
So, what about Stant, are they good?
I was looking at this one.
Stant Thermostats 431-14218 - SummitRacing.com
Old 03-25-2013, 12:37 PM
fastnloud's Avatar
Also, this stant is suppose to be better, but it's also cheaper.
Stant SuperStat Thermostats 431-45358 - SummitRacing.com
Old 03-25-2013, 01:38 PM
I had trouble with both Mr Gasket and Robert Shaw pill style thermostats.. I ended up pitching all that expensive junk and using the regular old Stant t-stat..
I get the smallest drill bit I have in my box and drill one hole through the stat.. Looks like Stant does a similar thing with the V notch..
The Following User Says Thank You to Bonneville462 For This Useful Post:
fastnloud (03-25-2013)
Old 03-25-2013, 06:55 PM
fastnloud's Avatar
Thanks, I was actually looking at one of the Mr. Gasket hi flows, but you wouldn't recommend them?
The Stant SuperStat is cheap, but if that's a good one, I can just go ahead and get that.
Old 03-26-2013, 01:04 AM
acme's Avatar
Thanks guys.
From experience I tried the 160, but a 180 or 195 ran smoother and it's better for the oil so it can burn off contaminates , condensation in your oil. Oil likes higher temps anyway.....An efficient radiator will keep a steady temperature that helps too.
The Following User Says Thank You to acme For This Useful Post:
fastnloud (03-26-2013)
Old 03-26-2013, 07:52 PM
fastnloud's Avatar
Thanks, I think I may try one of the Stant SuperStat 180's.
Old 03-29-2013, 09:22 PM
gonzo08383's Avatar
my motor is almost the exact same specs as yours except i run a comp cams thumpr. i have to run 93oct or i get pinging bad. try the hotter t-stat and drill a small hole for bypass. a regular mr gasket should work fine for the experimentation. hotter is more power and if your radiator can keep up you should be happy with the results
what degree thermostat in k1500 dannyessexc Hotrodding Basics 21 09-10-2016 12:23 PM
sbc 18 degree recomendations Aron427 Hotrodding Basics 5 01-21-2013 10:51 PM
SBC runs too cold with 195 tstat 68HellCo Engine 20 12-12-2011 09:16 PM
What are the advantages of running a 180* thermostat vs a 195* thermostat? batman09 Engine 7 01-09-2011 12:19 AM
SBC 18 degree head compared to 23 degree head powerwise? sb72elcamino350 Engine 7 03-09-2010 03:01 PM
