sbc 2 piece rear main seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2012, 03:11 PM
Ok just after a quick question I'm dropin in my crank have it cleaned ready to go is it better to off set the seal a bit so u get a better seal or no I have heard its a good idea but a lot of people don't do it
Old 11-09-2012, 04:37 PM
I always offset the seal jont by about a 1/4". Also, use some anaerobic sealer on the parting line. I think the GM stuff is Permatex 518???
Old 11-09-2012, 04:40 PM
Great thanks that's what I figured just everyone is a bit different
Old 11-09-2012, 06:57 PM
1971BB427's Avatar
I've never offset the rear main seals on a SBC or BBC, and haven't had any leaks. Maybe I'm just lucky.
Old 11-09-2012, 08:41 PM
On the Fel-Pro 2 piece rear main seal the offset is 3/8". Apply engine oil on the lip of the seals. The lip faces the front of the motor. Apply a thin layer of rtv on the mating surface.
Old 11-11-2012, 08:27 AM
I never offset seal theh rear seal and since GM has done millions and millions with no problems and I guess they have it figured out.
Had a engine come in once with an offset rear seal and when the cap was put on it pealed the back of the seal and stacked it up between the block and the cap causing a leak, Put the new seal no offset leaked stopped.
Old 11-11-2012, 09:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I've done them both ways. Using the offset was out of curiosity, never had a problem w/no offset but I had an engine that I knew was going to be run for a short time then removed so I figgered that would be as good a time as any to see. It didn't leak- but neither did no offset, so don't fix it if it ain't broke, I say.
BTW I have also never put anything on the rubber ends of the seals. Mated them together dry- no probs. The rear main cap DOES get a smear of RTV like shown in the factory manual.
Old 11-11-2012, 11:29 AM
GM has made millions of engines with no off set on the seal that did leak. They didn't go to one piece seals for nothing.
Old 11-11-2012, 02:58 PM
techinspector1's Avatar
Wiki Edits: 326
You must have gone to church before you installed the seal.
Old 11-11-2012, 03:33 PM
I must have as well and I have seen plenty of old cup engines in my shop with the seals not offset and they are the best of the best and they are having no problems LOL. And they must go to church as well.
350 sbc 1 piece rear seal 4 bolt main jrmz28 Engine 6 07-09-2011 12:35 AM
One piece rear main seal zz71s Engine 3 11-26-2009 08:04 AM
Need some help with 350 sbc 1 piece rear main seal housing eric32 Engine 5 06-17-2009 07:04 PM
SBC 1 piece Rear Main Seal Block Sinister Engine 7 04-27-2009 05:20 PM
Question on SBC with 1 piece rear main seal Houman SS '70 Engine 6 05-02-2005 11:18 PM
