SBC 2 piece rear seal information - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2006, 11:33 AM
My 327 SBC engine rear seal is leaking (more than what it should be, only 2900 miles on complete rebuild). I will pull the motor this winter and replace seal but I was wondering if anyone is using a different seal than GM's?
Old 10-15-2006, 11:39 AM
BOBCRMAN@aol.com's Avatar
There are aftermkt seals available that move the seal lip to a fresh spot on the crank. Try Fel-Pro or Victor-Reinz
Old 10-16-2006, 04:49 PM
I agree. Also, rotate seal ends so they are not in line with the bearing cap.
Old 10-16-2006, 05:14 PM
Known traffic menace
Fel-pro makes a double lip seal that works good, Cost a little more, But worth the extra cash. Perry.
Old 10-16-2006, 09:02 PM
We have aleays used the seals from Universal Molded parts which they call there Pro-Fit seals and the are made out of a red Viton rubber same as the a valve seals the standard seal is P/N 20350 and the offset seal isP/N 20283 and ther number is 1800-626-2967 ask for Greg Travis
And we have always installed these seals like GM does as we don't offset them in the block and no leaks so far.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
350 1 piece rear seal flex plate help 406 ss monte Engine 12 10-25-2005 03:25 PM
Engine swap (1 piece -> 2 piece rear oil seal bwery Engine 3 01-31-2005 09:39 AM
how-to exchange the one piece rear main seal 59vette Engine 4 08-19-2004 12:48 PM
T-350 rear seal leak billg_69gmc Transmission - Rearend 6 08-08-2004 02:55 PM
