Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc 283
Thread: sbc 283
Old 05-31-2006, 09:53 AM
jhs914 jhs914 is offline
Originally Posted by QUICKCHANGE
Bore On Stock 283 Is 3.875. So .080 Over Would Give You 3.955 Bore & That Would Give You 312 C.i. & The 327 Crank Is Interchangeable*Let me qualify that statement: pre 67 to pre 67 283/327 cranks should be interchangeable.
The 302 is a 4.00" bore and 3.00" stroke so a 3.955 bore on a 283 can't be 312 Cu. In. My Desktop Dyno calculates the 283 bored out to 3.955 as 294.8 Cu. In. However, back in the day, they were referred to as "292's".
You must be thinking of a 327 crank using that bore which comes out to 319.4 Cu. In. The 283 crank is 3.00". The 327 is 3.25".
