sbc 302 from a fuel injected 350??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2002, 04:10 PM
Question sbc 302 from a fuel injected 350???
I have access to a fuel injected 350 that is out of an '88 suburban. It needs rebuilt but its free so anyways... I was wondering if I have it rebuilt, could I have it made into a 302 using a 283 crank but still retain the fuel injection? Also, would I have a problem with the journal size? Any advice and/or help would be greatly appreciated. Thanks
Old 09-23-2002, 04:51 PM
Talking
A true 283 crankshaft has too small a journal to work. A real Z28 302 crankshaft has the correct journal size but the rear flange is wrong. GM has a adapter for this problem.
Old 09-28-2002, 10:11 AM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
Post
I too am trying to build a 302 from a 4-bolt 350. I can find spacer bearings to put a meduium journal crank in a large journal block, but as yet haven't found them to put the small journal 283 crank in a medium journal 350 block. If you find anything out, please post it so we can all share!!
Thanks
M.F. <img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Old 09-28-2002, 10:31 AM
deuce_454's Avatar
Post
hey Mrfixmaster i have a buildup article from hot rod magazine that addresses that problem of spacers and so on, send me an e mail at
jakob@regeur.dk
and ill send you the article, it also lists part numbers and sources for the 3 inch stroke crank in a big journal block.
Old 09-28-2002, 10:38 AM
deuce_454's Avatar
Post
jakob@regeur.dk
but why not just put in a 307/327 crank and add some long ford 300 I-6 rods they are 6.209 inches and costs less than 300 for eight with ARP bolts and floating pin bushings..?
and it will put your rod to stroke ratio at 1.9:1 just like the 302. with the added cubes of the 327
Old 09-28-2002, 07:00 PM
Post
souds great, i hate to sound dumb, but where do ya find pistons
Old 09-30-2002, 05:35 AM
NAIRB's Avatar
Post
Just get ahold of Wiseco, JE, or Ross ect and they'll custom make what you want for about 800 bucks!
