SBC 305 Heads on a 350 ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2007, 05:04 PM
I have a set of 305 heads casting # 376450 1975-81 305 60cc chamber. The set of 350 heads casting # 10110810 1991-up 350 Gen. 1, 65cc chambers and would like to know which are better performance wise on the 350 block. The 305 heads are from and 1980 camaro (i think) and the 350 heads are of an Earlie 90's truck. a also installed a higher performance camshaft.
Old 07-15-2007, 05:34 PM
i know its all mickey mouse but i just want to throw what ever is best together.
Old 07-15-2007, 05:51 PM
if you have to choose between the 2 i would go with the 350 heads
Old 07-15-2007, 06:06 PM
techinspector1's Avatar
Wiki Edits: 326
Posted by brawler"
"also installed a higher performance camshaft."
brawler, did you match the intake closing point of the camshaft to the static compression ratio of the motor? If not, the motor may be slower than it was with the stock cam.
Old 07-15-2007, 07:10 PM
sorry but i don't even know what that means or how to do it any more information would help.
Thank
Old 01-06-2009, 09:00 PM
Well i've got 305 (1 13\16 intake 1 1\2 exhaust) heads on a 350, that gives great 10:13 compression. it has great low end torque, with an exceptional high end torque. this 79 chevy pickup has a 150 mph at its peak. it is .60" bore with a with a $1500 budget. With Performance comp cam, EGR performer rpm manifold edlebro, 750 cfm performer rpm carb edlebro, domed sealed power pistons, roller tip rockers, and 3.11 posi, not including the turbo 400 tranny. Its fast I had a torque converter on there at one time, and I poped her front end high but it was to much for the street, it's a daily driver , 3.9 sec 0-60 havent 1\4 mile or 1\8 strip race. But i think the 305 heads is a awesome combination they can take the punishment, beleive me.
Also curious to what anyone thinks of the combination.
Old 01-06-2009, 09:20 PM
It really depends on which 305 heads you are talking about. If they are HO heads, they're ok. If not, what you gain down bottom will be lost up top. For the street, you will probably like the 305 heads better regardless because of more compression so it will have more bottom end. Id they are stock flat top pistons, I think you can still get away with pump gas. I would run 93 though.
Old 01-06-2009, 10:45 PM
Check out http://www.mortec.com/ on chev casting #'s
The 350 heads will flow more, the 305 will have higher comp.
Old 01-06-2009, 10:48 PM
Another note. The 90 350 heads are fuel injection heads and the two center bolts are drilled at a different angle. You can still use a carb intake, but must oval out the holes to make the bolts line up. Most times you will need to use a small head bolt like a header bolt for the two center bolts on each side.
305 head on 350 savman1 Engine 4 10-15-2006 10:18 PM
chevy 350 heads on 305 coolcars58 Engine 1 05-21-2006 01:23 PM
Will chevy 305 HO heads fit on a 350? sugarmonkey Engine 5 01-16-2004 08:07 AM
350 Heads on 305? JohnyR17 Engine 6 01-05-2004 09:53 PM
350 heads on a 305 molevolent_creations Engine 3 10-26-2003 04:36 PM
