Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 327 Build
Thread: SBC 327 Build
Old 05-04-2010, 09:15 PM
327NUT's Avatar
327NUT 327NUT is offline
Just a couple of comments, that cam is HUGE for a 327, won't idle worth a damn and you would need a big stall converter. The compression will be way too high with dome pistons and 55 cc heads, this combo work on a street car. If you want it really streetable use 9-9.5:1 comp and a cam that is around 260-270 deg max.
