Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 327 Build
Thread: SBC 327 Build
Old 05-05-2010, 06:28 AM
ap72 ap72 is offline
Banned
Originally Posted by Dreadhead
Would you recommend 2 or 4 valve reliefs ?... Probably going with KB Hypereutectic pistons.
with 55cc chambers I'd run 4VR pistons- HOWEVER if you've had those heads worked on (like they were cast for) then your chamber will not be the advertised volume unless the deck mating surface has been cut.
