Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 327 Build
Thread: SBC 327 Build
Old 05-05-2010, 08:08 AM
Dreadhead Dreadhead is offline
Originally Posted by 327NUT
Just a couple of comments, that cam is HUGE for a 327, won't idle worth a damn and you would need a big stall converter. The compression will be way too high with dome pistons and 55 cc heads, this combo work on a street car. If you want it really streetable use 9-9.5:1 comp and a cam that is around 260-270 deg max.
It's going to be taken to the track often to though. So if I did drop my cr to the low 10 range you would still recommend a 260-270 deg cam ?
