Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 327 Build
Thread: SBC 327 Build
Old 05-05-2010, 07:15 AM
ap72 ap72 is offline
Banned
Originally Posted by Dreadhead
Bought them from another guy (never ran) and highly doubt they've been ported... Think my best bet would be to take them to a machine shop so they can check them out and take it from there ? Only spent $300 on them thought it was a steal for a new set of aluminum heads.
As long as you don't mind dropping 750-1000 at a machine shop those heads can be made fairly decent.
As far as cam goes, I would NOT use that 292 cam, if you already have it then go ahead and use it but its far from ideal. If you want a race cam get a flat tappet solid cam with face oiling lifters, if you want a low maintenance cam then knock about 15 degrees duration off the one you selected. Better deal yet would be a solid roller cam, but most people can't afford that. a decent solid flat tappet cam with good lifters should run you under $300.
