SBC 327 Build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-05-2010, 09:38 AM
Banned
so what have you decided for compression, what headers are you using? I can help you find a cam if you want.
  #17 (permalink)
Old 05-05-2010, 12:03 PM
Low 10 CR. Not sure on what size headers maybe 1 3/4. Want max horse power and torque, and a real rough racy idle.
  #18 (permalink)
Old 05-05-2010, 12:22 PM
Banned
get long tube headers if you can, there's a BIG difference. What other details can you give?
  #19 (permalink)
Old 05-05-2010, 12:40 PM
Cool... I haven't bought any rocker arms yet but I'm definately going to get full rollers. 3-inch exhaust. SFI approved damper good for use up to 12,500 rpm.
  #20 (permalink)
Old 05-05-2010, 04:20 PM
ericnova72's Avatar
More for Less Racer
Sounds like you are on the right track. If you want to be the killer amoung your friends and be confident out on the street a solid cam is one of the keys that help open that door. Your plan as this thread developed goes hand in hand with that. Your planning on the roller rockers is good, get a stud girdle and good 1-piece chromemoly pushrods to go with them and the cam/EDM lifters.
I've always checked my valve lash about 2-3 times a summer, 5000 miles driven total in a summer and rarely found anything out of adjustment. I was also racing it(Drags)2-3 weekends a month, so it got run hard.
You will have to adjust then a couple times in the first few hundred miles, but after that the valvetrain parts are settled in and comfortable with each other and the lash rarely changes.
The smaller 327 will probably like 1-5/8" headers better than the bigger 1-3/4" which is a plus for you because they are common and cheaper
Were the heads complete or bare castings??
  #21 (permalink)
Old 05-05-2010, 04:27 PM
Thanx... And they're complete jus need to get some screw in studs and guide plates
  #22 (permalink)
Old 05-05-2010, 04:42 PM
ericnova72's Avatar
More for Less Racer
You got a pretty decent deal on them then You will want to check the springs on them, the current spring may not be good enough for a solid cam.
  #23 (permalink)
Old 05-06-2010, 06:54 AM
Banned
May be true, may not be true. You need to pick your cam first, and then see what the spring recommendations are for THAT cam. some require more, some require less spring pressure.
I would get a cam in the 240's duration, a 327 can stand a little wider LSA than a 350, something between a 108 and a 110, with about a 4 degree lobe split towards the exhaust side. It'll be fairly streetable but still give you plenty of power through 6500 RPM. A 240's solid cam will actually drive like a hydraulic cam with about 10-15 degrees less duration.
  #24 (permalink)
Old 05-06-2010, 01:51 PM
See thats the other thing. Summit only offers the victor jr intake for these heads. By my cam and intake basic operating range not matching up won't this cause me to actually lose power ?
  #25 (permalink)
Old 05-06-2010, 01:54 PM
Banned
Yes, but there's not much of a mismatch.
  #26 (permalink)
Old 05-06-2010, 02:17 PM
Oh ok... Well I'll be heading to summit to get the kb pistons and swap my cam this weekend. 240's solid lift cam or 225-240 Hydraulic lift cam correct ?
And are you talkin about duration @ .050" ?
  #27 (permalink)
Old 05-06-2010, 02:28 PM
Banned
Yes sir. Get a tighter lash cam too, one with lash settings at .025" or less.
  #28 (permalink)
Old 05-06-2010, 02:33 PM
Thats were I was thrown off a litlle I was lookin at the simple duration. Sorry about that still learning something new day by day... Wel I'll do a little reasearch and post up some that I find.
  #29 (permalink)
Old 05-06-2010, 02:47 PM
Banned
http://www.speedwaymotors.com/Speedw...Cams,3202.html
part number 91515001
This cam is a little big, but with a 3500 stall it should run fine for you. Its not the most fuel efficient cam but it'll run. Pretty good match for a Vic Jr. intake too. Requires good headers, 1 3/4" long tubes and a free flowing exhaust.
Something a hair smaller would give you better drivability, and a hair wider LSA.
  #30 (permalink)
Old 05-06-2010, 03:14 PM
Migh just go with that... I was also checking out this isky cam at summit CL201281
Best way to build 327?? chevelle327 Hotrodding Basics 4 01-10-2013 03:17 AM
SBC Build, Some Questions RandyJ75 Engine 8 06-11-2009 07:08 PM
What to consider when choosing your first SBC build? CandiMan Engine 16 05-25-2009 07:50 PM
possible 327 build yevgenievich Engine 26 09-03-2008 08:56 AM
327 SBC Build 71 Ventura Engine 5 07-28-2008 08:30 AM
