Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 327 with Vortec heads
  #18 (permalink)
Old 08-02-2012, 02:50 PM
ap72 ap72 is online now
How fast is fast enough?
Originally Posted by Ripper 410 View Post
is it the early '67 small jornal block or is it the late large jornal? if it is the small jornal not that it matters that much being it is a 327 I would not put anything smaller than 280 dur in it 327"s were notorious for not developing power til around 3000 rpms because of the small stroke if it is the small jornal you can rap it too 10000 rpm at the blink of an eye without doing any balancing or blueprinting if it is the large jornal you can safely hold 8000 before you need balancing and blueprinting for there time the 327's were screamers they love to turn and really were not designed for low end so as far as cam the bigger the better on this app.
Dumb post of the day winner!
With a 9.5:1 compression ratio and the 700r4 you're going to want a cam around 210/215 @.050". It won't idle that rough but it will be very driveable and get decent mileage. On a well assembled 327 you could see an honest 325hp which for a daily driver is plenty.
