SBC 327 with Vortec heads - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #16 (permalink)
Old 08-02-2012, 01:53 PM
is it the early '67 small jornal block or is it the late large jornal? if it is the small jornal not that it matters that much being it is a 327 I would not put anything smaller than 280 dur in it 327"s were notorious for not developing power til around 3000 rpms because of the small stroke if it is the small jornal you can rap it too 10000 rpm at the blink of an eye without doing any balancing or blueprinting if it is the large jornal you can safely hold 8000 before you need balancing and blueprinting for there time the 327's were screamers they love to turn and really were not designed for low end so as far as cam the bigger the better on this app.
Quick reply to this message
  #17 (permalink)
Old 08-02-2012, 02:50 PM
Banned
Dumb post of the day winner!
With a 9.5:1 compression ratio and the 700r4 you're going to want a cam around 210/215 @.050". It won't idle that rough but it will be very driveable and get decent mileage. On a well assembled 327 you could see an honest 325hp which for a daily driver is plenty.
  #18 (permalink)
Old 08-03-2012, 01:06 PM
Thanks, just got a lead on some springs i can drop in to Vortec heads without additional machine work. According to the vendor it makes them good 218 degrees durantion @ .050" w/ up to .550" lift.? Any input on experience using them would be appreciated.
DROP IN FIT VALVE SPRING KIT FOR VORTEC HEADS, HYD FLAT TAPPET CAMS, 110 SEAT PRESSURE
  #19 (permalink)
Old 08-03-2012, 01:27 PM
This is not the only problem with the Vortec, though a big one. The other problem where lift is concerned is the clearance between the bottom of the retainer and the top of the valve guide, the space occupied by the seal notwithstanding. For a the 062 type production Vortec head, a collision between the retainer and the guide occurs around .43 inch sometimes to as much as .47 inch of lift at the valve. So most everybody just uses .45 inch as a rule of thumb, though that can get you into trouble if you don't check. The answer to this is to machine the top of the guide to provide additional clearance for the retainer. There are also thinner than OEM retainers sold to provide a bit more space. There is also what's known as the ghetto-grind where the OEM retainer and the top of the guide is attacked with a grinder.
So you will not only have to insure the spring has coil to coil clearance usually no less than .050 inch per coil when the valve is fully open. But you've got to get inside the spring and measure the clearance between the top of the guide and bottom of the retainer with the seal installed. If using a positive seal this needs to become a measure from the top of the seal to the bottom of the retainer, this also needs to be no less than .050 inch.
Additionally when getting into really high lifts getting clearance between the side of the spring retainer adjacent to the rocker arm can be a problem. The need here is to grind on the rocker for clearance. Given this is an area of the rocker that sees the most stress, subtracting material can cause the rocker to break with easily imagined consequences. The best solution here and also one that helps these other clearance problems is the beehive spring which tapers in at the top and uses a smaller diameter retainer, thus the rocker doesn't need to be compromised.
With engine building, remember that the cheap way out of problems leads to expensive disasters.
Bogie
  #20 (permalink)
Old 08-04-2012, 05:22 PM
Just received the 700 trans any insight on the swap, would be appreciated. I will be searching for threads tonight. Also, regarding gas octane... I made a mistake 91 or 100 is all I have access to, 93 is not available in California.
  #21 (permalink)
Old 08-04-2012, 05:36 PM
vinniekq2's Avatar
91 octane will work with 9.5 iron heads.More overlap on the cam will bleed a little CR.make sure your cooling system is peak,..Is there methanol in your gas there?
  #22 (permalink)
Old 08-04-2012, 08:06 PM
FYI, more overlap doesn't "bleed off a little cr". The engine isn't even trying to make cylinder pressure on that part of the 4 stroke cycle. The intake valve closing point is what effects the "bleed off", as this is the only part of the 4 stroke cycle that the engine is trying to make compression. And long duration cams will have a later intake valve closing point. In fact, the intake valve will be open long after the piston is on the rise to make compression, thus reducing the effective compression stoke which reduces cyclinder pressure.
  #23 (permalink)
Old 08-04-2012, 08:14 PM
Great i wil try and make it work with 91 at around 9:4. The gas is available at Arroyo Parkway 76, the stand alone pump is red labeled with "racing fuel" 100 octane gas only $8.89 per gallon.
  #24 (permalink)
Old 10-07-2013, 12:30 PM
GatorNats's Avatar
I really appreciate the wealth of knowledge here guys. I just bought a 66 Chevelle the original 327 which has been upgraded in the following fashion:
-Double Hump heads
-268 duration 454 lift Cam
-Roller Rockers
-Demon 650 Carb
-GM 373 ring and pinion gear set
He says it makes 350hp??? Not sure, but any ideas on boosting this up would be great. What would a different manifold and headers do? Thx-Gator
  #25 (permalink)
Old 10-07-2013, 12:35 PM
vinniekq2's Avatar
welcome to the forum Gator,maybe start your own thread with as many details as you know?
  #26 (permalink)
Old 10-07-2013, 01:35 PM
techinspector1's Avatar
Wiki Edits: 326
There's really not much to add to this thread that is over a year old, except to put in my two cents worth concerning max lift on stock L31 heads.
If a fellow is to use anything over 0.425" valve lift in these motors without mods, he's asking for trouble. Is there room to do it? Yes. Are you using up the safety margin? Yes. You don't put a motor together without some play (safety margin) between the bottom of the retainer and the top of the seal to account for an over-rev.
  #27 (permalink)
Old 03-17-2014, 02:27 PM
Finally, got some progress done on the car. I'm sure its the same ol' story, got busy and a lack of monies stalled the project. Anyhow, dropped in the 327 engine and 700 tranny this weekend and will try and tackle the accessories this upcoming weekend.
Any guidance on how to measure the driveshaft? I know I have to get it cut a couple of inches.
Name:	327 in car.JPG
  #28 (permalink)
Old 03-17-2014, 02:43 PM
Wiki Edits: 326
http://www.iedls.com/asp/admin/getFi...&TID=28&FN=PDF
  #29 (permalink)
Old 03-18-2014, 08:27 AM
LOOKIN AWESOME!
Kudos to you on the follow up, we don't see that enough around here. PLEASE keep us posted. I don't think we see enough vortec headed street builds here. Theyre fine heads for the street. Can you imagine what guys would have went through to get Vortec head performance; at an over the counter price. In 1968; these would have been KILLER heads. They still are
  #30 (permalink)
Old 03-19-2014, 02:40 PM
Any suggestion on spark plugs? Do I look for a vortec engine plug or a 327 plug? gap? Thanks for the help trying to gather everything for this weekend. I'm using a generic HEI distributor.
Closed Thread
'63 SS Impala - 327 w/ Vortec Heads dschick Introduce Yourself 2 03-05-2012 03:54 PM
What Cam is best for stock L31 Vortec 350 heads? 327 Build Colder2012 Engine 7 06-13-2011 06:22 PM
1965 327 vortec heads/R700 kevenj Engine 4 06-06-2007 06:51 AM
Vortec heads on a 66 327 SBC jchav62 Engine 2 01-06-2006 11:47 PM
vortec heads on a 327? 68redimpala Engine 4 09-28-2003 09:05 PM
