sbc 327 wont crank after new distributor install - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2012, 06:57 PM
pacman350's Avatar
pacman350
I have a 64 sj sbc 327 and about 2 months ago i replaced the original 6 inch balancer with a 8 inch balancer that had the timing mark 10 degrees before the keyway and the original was 2 degrees before the keyway. i bought a chrome bolt on timing pointer for it. I replaced the the distributor because it was the computer controlled one that i replaced with a new vacuum advance one. So brought the timing mark on the balancer up to zero and it was on the compression stroke because i had the driver side valve cover off and both #1 valves was closed and i heard the air go past my finger. The problem is now it wont fire up at all but it will turn over i even swap the new coil for one of my dads truck and stilll same thing so i put the new coil back in. i checked to see if it had spark and it had a very weak orange spark. what do you think it can be the car is a 84 cutlass could the ignition switch do this. Its a all new distributor and the motor only has about 800 miles on it since a complete rebuild in march of last year.
Old 07-14-2012, 11:30 PM
SSedan64's Avatar
Are you getting full 12V+ to the Distributor?
Old 07-15-2012, 12:54 AM
pacman350's Avatar
pacman350
yes im getting 12 volts to it, problem solved the module had burned up, i got a module off another sbc that i have and put it in and instantly fired up the bad module even smelled burnt. thanks for you reply SSedan64
327, chevy
SBC front crank seal install stroker00s10 Engine 4 07-27-2011 08:11 AM
sbc distributor install 66SSNOVA Engine 10 08-10-2010 09:07 AM
327 Crank install Biscuit6447 Engine 5 11-16-2009 11:58 PM
Tool to install crank sprocket on a SBC? v8hed Engine 20 07-03-2008 05:45 AM
SBC 400 crank in a 327? anatram Engine 8 02-13-2008 05:38 PM
