sbc 350 305 heads on propane
I am new and have searched but haven't found great answers yet.
I just bought a jeep with the following sbc 350 casting - 3970014 - 67-70 350 block 305 heads - casting 354434 Mild cam flat top pistons - std -345np 4bbl propane setup My question is Is this a good setup - what kind of power can I expect - I have read that it will crap out above 5000rpm but has good low end torque. I guess I am looking for expert opinions about this setup and I am curious how many people run this kind of setup |
One reason they maybe put 305 heads on that motor might be because they maybe have smaller combustion chambers than 350 heads which would increase the compression ratio.
Propane doesn't have as much energy per gallon as gas, but it has much higher detonation resistance. That allows you to run at least a couple points higher compression ratio to make up for hte power loss with the less btu's of energy. However, the 305 heads will also considerably restrict power in anything above mid range rpms because of smaller valves and ports. One way around that would be to use Vortec style heads as they flow good and have small combustion chambers. A very good aftermarket Vortec style head that costs the same assembled as stock oem Vortecs is these http://www.rogersperformance.com/EQ.htm They have better exhaust port flow (Vortec's are a little weak) and they have more material to avoid exhaust valve seat cracking which can happen with oem stock Vortecs. They're available with the same small 64cc combustion chamber to up your compression - and you can also go with a thin head gasket such as .015, 016 or 020 available reasonable cost at Summit Racing. A mild cam will generally help build more compression, too, because the intake valve will close sooner while the piston is rising on the compression stroke. The critical thing in the cam is to have the intake valve close a little earlier on that compression stroke, which mild cams will generally do. You can find cams that are a little higher performance but that also close relatively early. Comp and Lunati are 2 good brands that have cams like that. Generally you probly want to stay with a cam that has less than 210 duration at .050 lift on the intake, and where the intake valve closes at or not much after 33 degrees after bottom center (on the compression stroke) at .050 lift. And you'd want a cam with around 110 to 112 max degree lobe separation rather than a computer / fuel injection type cam which will have 112 minimum up to 114 degrees lobe separation angle. Last edited by macx; 01-24-2011 at 11:22 PM. |
Yes, if you're running "dual fuel" you need the engine to be able to run on gas also.
If you're running straight propane you can take advantage of the higher octane rating, it's equivalent to 103 , to use more timing advance and higher compression to make more power and torque. Here is a link that contains articles talking about that. http://www.gotpropane.com/p11.html |
| how to build 454 to run propane with 600+HP? | propaine rockcrawler | Engine | 0 | 03-04-2007 10:12 AM |
| Propane | Chevy21 | Engine | 7 | 12-20-2004 06:32 PM |
| Propane conversion. | M&M CUSTOM | Engine | 17 | 11-27-2004 10:39 PM |
| Propane Injection | blown81 | Engine | 9 | 01-21-2004 04:55 PM |
| Using propane in a/c | propaniac | General Rodding Tech | 19 | 07-16-2003 05:09 PM |
