sbc 350 4 bolt block suffix code help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2002, 07:44 PM
Post sbc 350 4 bolt block suffix code help
Hi I have a 350 4bolt main casting number 3970010
the front and back have the 10 and 20 casted in them. I have V1206 TJO for suffix code. I cant find it listed any where. Usually nastyz28.com has it, but not this one. Also the date code says k133. If any one can id this for me I would appreciate it. I am wanting to sell it and want to have an accurate description. Thanks
Old 10-24-2002, 08:28 PM
DoubleVision's Avatar
Post
I couldn`t find a TJO suffix, closest i found was TJU which was a 1973 350 in a bus or a van, the numbers 10, 20 mean 10 percent tin, 20 percent nickel in the casting, meaning less wear occurs due to harder metal, heavier duty block, the date code of k133 is November 13th 1973. I`ve heard 4 bolt blocks of that vintage with a standard bore can bring $200, but it depends on who wants it. hope i`ve been of some help.
