SBC 350 bearing clearances - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2002, 04:07 PM
New Member
Question SBC 350 bearing clearances
I tried the best I could to find the info in my
" How to rebuild a small block Chevy" book, but I did not have any luck.
What I need to know is the rod bearing and main bearing clearances.
I plan on plastigaging them when I put this beast back together this weekend and wanted to make sure my machinist did his job right.
As always, thanks for the help.
Paul
Old 10-10-2002, 04:18 PM
NAIRB's Avatar
Post
The factory oil clearance allowable limits will be more than what I consider to be a good fit. I'm sure this will get alot of feedback, because some guys think loose is the way to go, but .0018-.002" is what I like to run on the rods, and .002" to 0025" on the mains, but I prefer my engines to be closer to .002" on the mains also. Sometimes, depending upon the housing bore dimension on the rod and main, it's hard to keep bearing clearance tight even if your crank is on the "high" limit. The factory usually allows an extra .0005" on the rear main.
If you have a main or two that ends up with almost .003" clearance, don't panick, you'll be okay.
Old 10-10-2002, 05:40 PM
New Member
Thumbs up
NAIRB,
Thanks for the quick reply, I'm always grateful for the great information you guys provide the board.
Paul
Old 10-10-2002, 05:41 PM
New Member
Thumbs up
NAIRB,
Paul
