SBC 350 Carb Recommendations - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2013, 07:20 PM
Hey guys, I'm new to the site (although I've been creeping in the background doing a lot of searching).
I'm looking for Carb recommendations for my SBC 350 that I'm building. From my searches, I'm torn between a 650 and 750 cfm.
Here's my current engine setup that I'm building:
1974 SBC 350 - Stock Bore
Flat Top Pistons
64cc Edelbrock Performer RPM Aluminum Heads
Edelbrock Performer Intake
Comp Cams Thumpr Cam
MSD Pro Billet Distributor, 6AL box and coil
I realize the Thumpr cam isn't a high HP cam, however it has what I'm looking for. I have done some research and see that the vacuum pressure is the biggest issue that I may have, so I want to make sure I purchase a Carb that will work the best.
Any recommendations are appreciated!
Old 01-20-2013, 09:24 PM
vinniekq2's Avatar
I would use a 750
Old 01-20-2013, 09:26 PM
Thanks Vinnie. I appreciate it!
Old 01-20-2013, 09:48 PM
Here is the Holley interactive Carb selector. Holley Interactive Carburetor Selector. Try it out see what you come up with. Stay away from the street avenger series carburetors. 650 CFM FOUR BARREL STREET CARBURETOR PART #: 0-80783C, 650 CFM FOUR BARREL STREET CARBURETOR PART #: 0-9895, 750 CFM FOUR BARREL STREET CARBURETOR PART #: 0-80508S. Here is three carburetors for you to check out.
Old 01-21-2013, 06:12 AM
If your intake is a spread bore then you should use a spread bore carb.
I like the edelbrock RPM intake (not rpm air gap) with a holley 3310 (750 vacuum secondary) on just about any street/strip chevy V8 build. Works well on street driven engines up to 450hp.
Get a 750 cfm if you get a vacuum secondary carb. Or a 650 cfm with mechanical secondarys.
Old 01-21-2013, 06:19 PM
BlenderHead's Avatar
just wondering.... why do you say to stay away from Street Avengers?
Old 01-21-2013, 07:53 PM
Imo the 750 cfm 3310 for example is a better carburetor than a 770cfm street avenger. These street avenger carburetors are just factory replacements not hi performance carburetors like the Holley 4150 series, Speed Demon and the Quick Fuel carburetors.
What carb should I get for my 350 sbc? grandslam1991 Hotrodding Basics 3 03-13-2012 10:14 AM
carb recommendations exaviour Hotrodding Basics 2 09-07-2011 11:52 AM
350 SBC mod recommendations C10Mike Hotrodding Basics 9 02-15-2011 05:40 PM
Carb Recommendations? mattson70 Engine 17 02-04-2007 01:15 PM
Carb to TPI on a 72 SBC 350 trees Engine 7 10-03-2004 07:42 AM
