-   -   sbc 350 changing 700r to th350 (http://www.hotrodders.com/forum/sbc-350-changing-700r-th350-139907.html)
frank88chevy 06-05-2008 04:06 AM
the motor is a lo5 350 crate roller block one pcs seal beside drive shaft length what mysteries will i need to know about flex plate and starter issues if i need parts i would like every thing on hand any help would be appreciated
Crosley 06-05-2008 10:19 PM
the converters share the same bolt pattern if the t-350 has the 11 inch converter, which it should
