Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc 350 changing 700r to th350
Old 06-05-2008, 09:19 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by frank88chevy
the motor is a lo5 350 crate roller block one pcs seal beside drive shaft length what mysteries will i need to know about flex plate and starter issues if i need parts i would like every thing on hand any help would be appreciated
the converters share the same bolt pattern if the t-350 has the 11 inch converter, which it should
