Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc 350 con.rod? please help
Old 08-20-2003, 11:12 AM
66chev 66chev is offline
New Member
If you are trying to find out if it is 6" or 5.7" etc. you can measure the distance between the large end hole and the small end hole, then add 1/2 the diameter of the large hole and 1/2 the diameter of the small hole, this will give you the rod length.
