-   -   sbc 350 con.rod? please help (http://www.hotrodders.com/forum/sbc-350-con-rod-please-help-21619.html)
inkfixer73 08-20-2003 11:07 AM
can anyone tell me how to tell what size my connecting rods are.Is there away that i can measure them to find out the size. Thank you..
66chev 08-20-2003 11:12 AM
If you are trying to find out if it is 6" or 5.7" etc. you can measure the distance between the large end hole and the small end hole, then add 1/2 the diameter of the large hole and 1/2 the diameter of the small hole, this will give you the rod length.
jimfulco 08-21-2003 01:26 PM
Or take the cap off, stand the rod upright on a table, and measure how high off the table the center of the small hole is. Unless the motor's still together. If it's a factory stock 350, they are 5.7". If it's been hotrodded before, it's anybody's guess as to rod length or even displacement.
V8 S-10 08-21-2003 02:47 PM
Just for the record there are 3 different length rods used in
stock smallblock Chevys
262-350s have 5.7 rods
400s have 5.565 rods
the 94 and later 265 v8s have 5.94 rods
