Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc 350 cranks slow when hot
Old 09-13-2012, 11:33 AM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
A starter kit will not improve the cranking when it's hot. It only good when the soleniod will not engauge because of a hot engine heating the soleniod.
You need a super high torque mini starter to make it crank faster. Also check the battery charge volt it should read 14 to 14.5 volts when running.
The Following User Says Thank You to lg1969 For This Useful Post:
the82elco (09-13-2012)
