Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc 350 cranks slow when hot
Old 09-13-2012, 12:38 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
Also check if battery ground is bolted solid to the engine block and there is no corrosion around the lug of the ground cable and battery terminal and the cable itself. Like oldchevy1956 wrote, you need a "good solid ground" connection. Make sure the battery does not have a dead cell.
The Following User Says Thank You to lg1969 For This Useful Post:
the82elco (09-13-2012)
