Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc 350 cranks slow when hot
  #24 (permalink)
Old 09-14-2012, 06:37 AM
dogwater dogwater is offline
Last journal entry: Still running strong
I had the same problem,what I did is I wrapped my headers,mainly to get rid of under hood heat and I chunked the overly large Chevy starter an replaced it with a 4.3 v6 starter.No more starting problems.I shaved off 9 1/2 lbs. with the starter change.My battery is in the trunk,run your ground wire to a tail shaft housing bolt if your using an auto trans.
And the more bigger the wire the more gooder.....
The Following User Says Thank You to dogwater For This Useful Post:
the82elco (09-14-2012)
