Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc 350 cranks slow when hot
  #25 (permalink)
Old 09-14-2012, 01:51 PM
the82elco the82elco is offline
Originally Posted by dogwater View Post
I had the same problem,what I did is I wrapped my headers,mainly to get rid of under hood heat and I chunked the overly large Chevy starter an replaced it with a 4.3 v6 starter.No more starting problems.I shaved off 9 1/2 lbs. with the starter change.My battery is in the trunk,run your ground wire to a tail shaft housing bolt if your using an auto trans.
And the more bigger the wire the more gooder.....
what kind of car did u get the the starter from?
