sbc 350 cranks slow when hot - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-13-2012, 01:21 PM
Originally Posted by DoubleVision View Post
Since I've did many performance builds with headers and high compression and never had any starter issues says to me the chevy starter has no issues with doing the job, however it's important it be did right. Before you do anything first off, and this is vital, Improve the grounds. If you've got what I've seen on the majority which is ground cable going to alternator bracket that ain't gonna cut it. Run the ground directly to the block. Make sure where you connect it on the block is sanded down to it makes a excellant contact. Next run another ground from the block to the frame and again, make sure it's getting a good connection. If there are factory ground straps hanging around unused from the firewall reconnect them.
Next, get the vehicle on a set of ramps and torque the starter bolts to 35 ft lbs.
This is what I've did on each build I've did and none give me any problems. What made me start doing it this way? Before I did it my car ate a total of Eight starters and I'd decided enough is enough.
When you improve the grounds you'll notice everything in the electrical system will work better.
THANKS i will definitely do ^^
  #17 (permalink)
Old 09-13-2012, 01:29 PM
Choctaw Bob's Avatar
And don't forget when you clean the battery terminals, check the cables inside the insulation a few inches from the terminals. Corrosion has a way of sneaking up the cables and causing damage you can't see.
The Following User Says Thank You to Choctaw Bob For This Useful Post:
the82elco (09-13-2012)
  #18 (permalink)
Old 09-13-2012, 02:45 PM
one more thing what size ground wire to get?
  #19 (permalink)
Old 09-13-2012, 02:53 PM
If you search ground cable on Jegs, you will see that all are #2 gage.
  #20 (permalink)
Old 09-13-2012, 03:02 PM
F-BIRD'88's Avatar
Yada Yada Yada
ALL these things are very important. Once you have corrected ALL these areas that effect starter motor performance you can also install a simple ignition power interupt toggle or pushbutton switch on the dash to allow you to disable the spark momentarily for hot starting. This removes the cranking load on the starter allowing you to crank over and purge the intake manifold of over heated over rich air fuel that will not burn.
This is why a hot motor needs to crank for a longer time to start.
Once a fresh air fuel mix is drawn to the intake manifold the motor will start instantly.
Kick it over 1- 2- 3 count and throw the switch. pretty simple.
Make sure the GM OEM rear starter motor bracket brace is installed. The two bolts alone are not enough to support the GM starter motor.
This is not a replacement for correcting the other issues grounding, heat shield etc.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
  #21 (permalink)
Old 09-13-2012, 06:17 PM
does my alternator need a ground?
  #22 (permalink)
Old 09-13-2012, 08:29 PM
Look at your documentation. it could be in the plug hole or one of the unoccupied posts or it may ground to the case.
  #23 (permalink)
Old 09-13-2012, 11:04 PM
Look at what appear to be terminals. The big one should be hot or positive. The others could be marked ground and field.
  #24 (permalink)
Old 09-14-2012, 06:37 AM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
I had the same problem,what I did is I wrapped my headers,mainly to get rid of under hood heat and I chunked the overly large Chevy starter an replaced it with a 4.3 v6 starter.No more starting problems.I shaved off 9 1/2 lbs. with the starter change.My battery is in the trunk,run your ground wire to a tail shaft housing bolt if your using an auto trans.
And the more bigger the wire the more gooder.....
The Following User Says Thank You to dogwater For This Useful Post:
the82elco (09-14-2012)
  #25 (permalink)
Old 09-14-2012, 01:51 PM
what kind of car did u get the the starter from?
  #26 (permalink)
Old 09-14-2012, 03:21 PM
Problem Solved thanks for the help! no more slow cranking
SBC 350 dies when hot 57dreamer Engine 12 06-07-2011 06:17 AM
Starter turns slow when hot dasyhard Hotrodding Basics 9 05-24-2011 11:55 PM
350 sbc running hot on highway Jim7231 Engine 25 08-21-2010 02:18 PM
Why is my sbc chevy 350 getting so hot? batman09 Engine 17 08-22-2004 07:37 PM
Chevy starter cranks and cranks, cranks Walker Engine 5 07-22-2003 12:33 PM
