sbc 350 with dual flowmaster blowing twice as hard on driver side - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2012, 02:18 PM
91chevyss's Avatar
i have a 91 chevy silverado with a 350 that i switched to an edel 750 with dual flowmasters with turn downs it has beening running fine until the other day it sounded like one side of the exhaust was thuttering going down the road well today i had it running and it was popping through the carb a little but the driver side exhaust was blowing way harder than the pass. side. driver side will blow dirt and grass and pass side will barely move the grass. any ideas. is that normal for the exhaust. i even pulled the pass. side exhaust completely off and left just the header and still pushing out the same amount of air. driver side will move the skin on my hand. thanks
Old 11-03-2012, 03:08 PM
Sounds like you have a couple dead cylinders pop off a valve cover maybe you have a valve that isnt opening up if there isnt anytjing obvious start it up to see
Old 11-03-2012, 03:34 PM
techinspector1's Avatar
Wiki Edits: 326
Remove the passenger side valve cover and start the motor and let it idle. You're looking for rocker arms that move slightly or not at all compared to other rocker arms. Yes, it will splatter oil all over, but you can minimize the splatter with some cardboard bent into a U shape and held so that the oil hits the cardboard and runs back into the head.
Old 11-03-2012, 10:58 PM
91chevyss's Avatar
ok ill try that tomorrow if i get a chance and ill check the spark plugs also and let yall know. to me the driver side feels like its blowing to hard and the pass. side feels somewhat normal. but thanks for the help so far.
Old 11-04-2012, 12:45 AM
vinniekq2's Avatar
or you can turn the valve cover upsidedown to catch over flow oil
Old 11-04-2012, 06:47 PM
91chevyss's Avatar
well i checked the spark plugs earlier driver side was more black than anything on all 4 . pass side was more tan on all 4. i think it was number 3 or 5 that was black all the way around. im currently running bosch platinums. im gonna take the valve covers off tomorrow. any other ideas if the rockers check out ok. im running with a edelbrock torker intake and 1 inch spacer under carb. but its never made the noise that its making now. thanks.
Old 11-06-2012, 03:26 AM
91chevyss's Avatar
still nothing
i ran it a little bit without the valve covers couldnt really tell a difference between the rockers but there was one or two rods i couldnt turn. i may take the springs out to check the pressure on them. would the breather on the valve cover make a difference its on the driver side. could it be the driver side getting more gas make the plugs black and make the exhaust have more pressure and make the noise im hearing just wondering.
Old 11-06-2012, 09:33 AM
hcompton's Avatar
Old & Furious
Take it to a shop and have them do a compression and leak down test. I bet you got a bad valve or somehting else. Unless you have a compression tester or can rent one from local store.
The exhuast should be equal or really dam close. Something is wrong with the setup. If it was injected I would think one bank of injectors was not firing.
Push rods should be tight if the valves are open and should be loose enough to turn with your fingers if the valves are closed. You can turn the engine over by hand and see if they lift all the way up and get loose when they close. Always tight or alwasy loose and you have found your issue.
I usally check all the rockers with a small metal ruler to see if they are all going up and down the same amount. With in reason they will not be perfect but should be damn close. If not its your cam. I usally do this with the engine off and turn it over by hand for this. You can put the bottom of the ruller up agaist the valve cover gasket area and lean the ruler to reach the back of the rocker arm. Should be able to measure all of them the same way.
hope this helps
Old 03-04-2013, 06:22 PM
91chevyss's Avatar
done a compression test today and my numbers are
cyl# pressure
1 155
3 152
5 143
7 145
2 50
4 42
6 35
8 49
Now what could be wrong. Is it an exhaust leak or all my springs bad on the pass. side. That something I had happen to the compression tester between the time from the driver to pass. so I went back to the driver side and number #1 was still 155.
plug on 350 trans driver side a-ortiz74 Transmission - Rearend 3 10-13-2010 06:04 AM
which heads on which side of SBC 350 075turbo Engine 3 01-22-2010 09:18 AM
Passenger side dip vs driver side dip in early Nova dirtinla Engine 1 11-20-2008 01:45 PM
Chevy 350 knock driver side? Help jimenezaldo Engine 18 09-01-2005 05:38 PM
what kinda power does a 350 van motor make?(80's model van driver side dpstick) bambam36862 Engine 5 08-31-2003 03:54 PM
