Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 350 Engine Advice needed
Old 10-31-2012, 02:05 PM
Clayton A's Avatar
Clayton A Clayton A is offline
Originally Posted by techinspector1 View Post
Here's your cam.....
Saturday Night Special, Part #110691, operating range 3,200 to 6,800 rpm's.
Flat tappet hydraulic, Performance usage, good mid and upper RPM torque
and HP, bracket racing; Street, Heavy, ProET, SuperET,
etc., autotrans w/3500+ converter, oval track; Street
Stock, Enduro, Hobby, etc., 1/4-3/8mile circle track, 10.5:1 to 12.0:1 static
compression ratio advised.
Advertised duration: 294/300
Duration @0.050" tappet lift 238/244
Lobe separation angle 106 degrees
Valve timing @0.050" tappet lift:
Intake opens 17 degrees BTDC
Intake closes 41 degrees ABDC
Exhaust opens 52 degrees BBDC
Exhaust closes 12 degrees ATDC
Intake valve lift with 1.5:1 ratio rocker arms, 0.480"
Exhaust valve lift with 1.5:1 ratio rocker arms, 0.495"
So, to answer your question, would this be too much cam for these heads? The answer is yes. The heads will stall and sign off way before the cam is done pulling. You fellows have to realize that the L31 heads were designed by GM to make the proper hp and torque to haul grandma and the kids to Disneyland, not to do things like bracket racing (description of the cam above). They're great street heads and will flow better than any other PRODUCTION Chevy cast iron head, but they are not miracle heads.
When I built this engine I didn't have a clue of what I was doing and was just throwing parts together. I still don't know what I am am doing but at least now I am smart enough to ask people that do! lol What type of cam do you recommend for the heads?
