are sbc 350 gaskets sets the same despite the year and/or if its a vortec??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2009, 04:35 PM
okay i need to buy a new gasket set for my 350 and i know for a fact the ppl say that there are specific applications to vehicles and engines and stuff but it is a load of crap like all parts store sell gmc and chevy engine parts as diff catagories... psshh idiots its a 350 they arnt diff engine parts if there the same year... sorry to say same with shocks there is no such thing as a vehicle specific shock... NO NOT GONNA HAPPEN!! they are specific to the height of the shock and a few other minor things so i have been around this block many times which is why i am so frustrated (you might have guessed) with this situation, i know 350 gaskets are pretty much universal with other 350 up till they went to horrificly heinous fuel injection the bane of my exsistence anywho, my 350 i got is a 95 or 96 one of those and it is throttle body injection so it doesnt have like the injector o ring gaskets or w/e they are and all that special garbage that normal efi or tpi have but the only thing is that the engine is a vortec engine, wanna say its a L31/ 5700 vortec or somthing like that and i know a normal gasket set will fit it but i dont know if it has to be specific for a vortec (like everything else on a vortec does) what i mean is like if the ports are just a tiny bit diff size or if they are spaced just a lil diff. but i really need to know before i go blow the little money i have on the wrong gasket set, so any help at all would be very much appreciated
Old 08-17-2009, 05:27 PM
artsvettes's Avatar
I think the only way that you will get the specfic part for your engine is from the dealer. I did a search on Advanced Auto for head gaskets for my 77 corvette 350. I then did a search for the 97 350 vortec head gasket. Take a guess it came back with the same felpro part number. The thing about it is the 77 came with a steel shim gasket the replacement felpro is a thick composite gasket.
Old 08-17-2009, 05:32 PM
OPPS, I forgot
The head gaskets for GEN I engines are common, the intake to head port gaskets are not for Gen I's 1995 and older compared to 1996 and newer.
If it's a 95 it uses swirl port heads and TBI, this is pretty much the same top end gasket set as aways used with the exception of some raised port race heads which for the most part are not production items.
OOPS, I forgot to mention that looking at the 1995 block casting number can screw with your mind. The Vortec 880 block was introduced during the 95 production run. However, it mounts Swirl Port heads, TBI, and OBDI engine management as all other 1995's. So don't just go by casting numbers to ID a 95 model engine.
If it's a 96 it is stickier as nearly all used the L31 Vortec, OBD2 computers with central port sequential cylinder injection. But some, mostly vans, came with OBD1 TBI on what otherwise was the L31 Vortec long block. However, all of these take the upper end gasket set unique to the L31 Vortec Head. This is because the Vortec uses a 4 bolt per side attachment pattern instead of the older 6 bolt pattern, the Vortec head also has raised ports compared to the older heads so a regular gasket set not only has the wrong bolt pattern but isn't tall enough to seal the ports.
Bogie
Old 08-17-2009, 05:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are enough differences that you need the correct set for your engine. Be sure its the correct app- use the VIN to determine if you have a Vortec or LT1- they are very different as to gaskets also- just as different as a, say, 1973 350 cid SBC is from a 1996 Vortec 5.7L SBC.
Don't believe everything you hear- even about shocks being "one size fits many". There are differences, some subtle, others not so subtle- else the companies that manufacturers them (IIRC, there were two main co.'s- Gabriel and Monroe) would not go to the expense of having so many part numbers. They gain no advantage by having so many p/n's, just the opposite, actually. It's a necessity.
Old 08-17-2009, 05:44 PM
fast68's Avatar
likes chevy trucks & boobies
sbc heads and gaskets changed over the years
although the head gaskets are same 55-95 the heads castings changed s intakes are different and gaskts slightly changed as well
the general breaks on sbc engine changes are
'55-79
'80-86
'87-'95
but most gaskets stayed same as the heads and intakes changed castings and designs
then there are some carb 88 and 89 engines in caprices and 87 88 camaros firebirds and maybe a couple others and also heavier trucks like 1 tons etc that kept using carbs later than 86
sp you will want parts for what year make model the engine is from especially if it is late '80's up
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
350 sbc Shortblock and vortec heads 1970Chevy Engine 2 09-23-2007 04:21 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
350 SBC...specific years? 78SilverShark Engine 2 10-14-2003 07:20 PM
