-   -   sbc 350 Head Gasket question (http://www.hotrodders.com/forum/sbc-350-head-gasket-question-87720.html)
oregon chevelle 04-24-2006 10:42 AM
I had my aluminum heads at the shop getting new seals, springs and the valves ground and now need to put it back together. The former gasket had a .038 gasket thinckness. Which gasket would be best for me to use. The engine is a 350 bored .030 with aluminum TFS heads. Deck height says -.001 on the paperwork. I do not see any 4.030 bore gaskets so I am assuming they must use a bigger bore on the gasket than the actual bore of the motor? Is this right and which gasket should I look at getting.
johnsongrass1 04-24-2006 01:25 PM
Felpro 1003. 4.166 bore by .038 compressed thickness. 9.3cc volume for compression calc.
Right, it won't brinell.
