SBC 350 head torque sequence - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2005, 03:28 PM
tnman's Avatar
New Member
Question SBC 350 head torque sequence
Can someone give me the torque sequence for sbc 350 heads?
Thanks
I just found it!!! Thanks!!
Old 01-26-2005, 10:44 AM
willys36@aol.com's Avatar
Wiki Edits: 21
You might as well post a picture of the answer here so anyone doing a search will benefit!
Old 01-26-2005, 12:13 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
The site in the KB is dead for the info.
Here is a site that shows it, plus one for ALL intakes.
Heads
http://www.holley.com/TechDocs/Instr...%20300-571.pdf
Torque Sequence for Intake
http://www.nationaltbucketalliance.c...que/torque.asp
Luv the smell of NITRO in the morning.
Old 01-26-2005, 02:17 PM
The general rule is torque from the inside out. That is torque the bolts in the center of the head first and work out from there. And torque up in a few stages.
The same rule will work on the intake. inside to outside.
I don't think the "exact" order is that critical.
When removing to the opposite, loosen the outer bolts first and work towards the center.
Old 02-15-2010, 12:24 PM
Great link to 350 info
Here is the guild I used on my 62 Bel Air 350 build. It shows the torque spec and pattern to use.
http://www.boxwrench.net/specs/chevy_sb.htm
Old 02-15-2010, 01:07 PM
Engine machinist/builder/cnc
For heads, mains you want to have the steps at a minimum, 15 ftlbs apart. This is due to break away torque being higher from friction.
