Sbc 350 Hei. Ran Great. Now No Spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2010, 06:23 PM
1972 chevrolet k20. with a new crate 350 sbc. new edelbrock 650 cfm carb' intake manifold' fuel pump' fuel lines. new 6 inch lift on 35 inch dick cepeks.. neways i was driving it a day ago and i went around a corner and stomped on it burning out. and it did' but when i got to the light it started to stumble and then died. now i have no spark at all. the way i have checked for wether i have spark or not. is i took a allen wrench and stuck it in the plug wire' held it close to the ground and then had a friend crank the truck over. no spark. the way my hei is wired up is a hot lead from the battery to a switch then to the hei. is this the correct way to do this?
Old 01-17-2010, 10:39 PM
n_keiser_rat's Avatar
its homemade, and its cheap!!!
it sounds like a ignition moduel or the coil, but make sure you still have power to the distributer before you just start changing parts
Old 01-18-2010, 12:24 AM
im sure i have power going to it.
i believe its the pick up coil. but what would make my truck seem like it just bogged out... then died' now it has no spark at all. but when i try to turn my engine over. it makes a funny sound. i cant describe it. like its flooded or something.
Old 01-18-2010, 12:35 AM
well i would just start trouble shooting it and see what you figure out, first i would check to make sure you still have power to the coil. it could of shorted out and thats why it did that. thats the easyest and cheapest way to get stated, it also kinda gives you a starting point, if your getting power to it then you know its either the coil or the ignition module, if it doesn't have power then you know it shorted out or lost connection somewhere...
Old 01-18-2010, 09:25 AM
Check for power to the ignition first, and fix it if necessary.
Based on your strange noise description, I'd then pull the cap and make sure the rotor is turning and all the pieces inside are intact. Maybe the distributor is not turning over right, or the rotor fractured inside the cap.
Bruce
Old 01-18-2010, 02:27 PM
i figured it out.
i wasnt getting a full 12v and the magnetic pick up in the cap was bad. real worn out. so i did both those things. and shes back.. thank you all very much for all your help. it was really helpfull
350 TBI spark problem driving med crazy!! Erst Engine 13 09-27-2016 05:39 PM
350 sbc pistons Thumpr Engine 5 09-08-2009 06:02 PM
are sbc 350 gaskets sets the same despite the year and/or if its a vortec??? Rod stalker Engine 4 08-17-2009 06:44 PM
cHEV 4.3L Bore size..compare to SBC 350 (both stock) boneyard Buick Engine 5 09-25-2006 08:29 PM
72 350 w/ HEI won't start roadbase Engine 3 07-14-2005 02:33 AM
