Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 350 and Holley street dominator
Old 07-19-2013, 10:34 AM
eric32 eric32 is offline
I have a weiand stealth high rise intake same bolt pattern style as yours. I can't get anything regular on it except a box end wrench but I had to grind down the end of it around the radius with a bench grinder and it fits fine. Just go get a decent wrench and grind it down a bit around the whole radius and it will fit just fine. I also have a cheap distributor wrench that splits in half and allows you to hook up a ratchet to it and it fits just fine with no grinding and I use it to torque my inner bolts with it too. Those cheap distributor wrenches you can get at advance autoparts or autozone.
