Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 350 and Holley street dominator
Old 07-24-2013, 11:34 AM
v8xj v8xj is offline
Originally Posted by eric32 View Post
I have a weiand stealth high rise intake same bolt pattern style as yours. I can't get anything regular on it except a box end wrench but I had to grind down the end of it around the radius with a bench grinder and it fits fine. Just go get a decent wrench and grind it down a bit around the whole radius and it will fit just fine. I also have a cheap distributor wrench that splits in half and allows you to hook up a ratchet to it and it fits just fine with no grinding and I use it to torque my inner bolts with it too. Those cheap distributor wrenches you can get at advance autoparts or autozone.
Do you adjust the torque numbers because of using that wrench or does it matter?
