sbc 350 horsepower advice needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2006, 07:10 AM
I have a 1976 chevy 350ci, 4-bolt main I am working on. The engine is low milage and in good shape. I will be putting it in a 1972 chevelle, which I want to be streetable. The heads are stock 75cc (1.72 intake, 1.50 exhaust). Can I get 300+ HP using these heads and upgrading cam, intake, and carb ? If so, what should the combo of cam, intake, and carb be ? Im planning on headers for exhaust. Any advice is appreciated.
Old 12-30-2006, 07:24 AM
poncho62's Avatar
Wiki Edits: 5
Very doubtfull..........you can find much better stock heads than those. Those must be truck heads. Most passenger car heads from 350s came with 1.94 valves.
Old 12-30-2006, 08:02 PM
327NUT's Avatar
Personaly I would'nt do any upgrades to that motor until I changed the heads. You're just waisting your time and money. Buy a set of Vortechs, a Comp Cams XE262-H or a little hotter XE268-H, an Edelbrock Performer intake and a 600 Holley or your preference and you'll have a sweet, streetable motor that will be well over 300 hp.
Old 12-30-2006, 11:06 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
I was in the same position as you are now about 4 months ago. What did I do? Bought an edelbrock performer intake, 650 thunder series carb(lots of room to grow yet small enough not to flood a near stock 350). I put this in my 74 Nova SS with a set of headers. It works great and I have plenty of room to grow from here as I see fit. I have the same heads on the motor as you do and it all works pretty slick.
From here as soon as the money becomes available I can buy a new set of heads. If your on a budget his is the route I would suggest. This way you are adding what makes sense and always allowing yourself to expand in the near future.
305 head on a 350 sbc Trav Engine 41 04-13-2013 08:30 AM
350 advice 73AggieVette Engine 4 02-09-2006 04:32 PM
88' 350 SBC Timing. HOW? help!!! 1966impala Engine 5 10-03-2003 05:09 PM
building a chevy 350, need some advice v8s10 Engine 5 10-28-2002 02:43 PM
350 rebuild advice Curly Engine 1 10-05-2002 07:47 AM
