Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 350 missfire at idle in gear
Old 04-24-2012, 06:45 AM
ragee517 ragee517 is offline
Well it was isolated to one cylinder then I changed the dizzy since I couldn't get the timing down lower them 12 degrees btc without the times becoming iradic jumping from 4 degrees after tic to way off the chart btc. Then I found that the rotor could bounce cause the weights weren't being held by the spring. So I switched the dizzy and forgot to recheck the timing to see if I could get it to set where it needs to be. So ill get some new spark plugs on friday and try to set the timing. Ill keep you guys informed on what I find out
